Aluminum Corrosion
RobertTX
02-28-2002 05:49:07
When working on the magnetos, I find screws and other parts that are stuck by the corrosion of the aluminum (potmetal) housing. What is a good penetrant / loosener for this? The normal rust busters like PB, Kroil, etc. dont have much effect. I guess the corrosion is aluminum oxide - a white, chalky looking stuff. Probably an acid would work, but I am concerned about harming the parts.
Rod (NH)
02-28-2002 06:43:35
 Re: Aluminum Corrosion in reply to RobertTX, 02-28-2002 05:49:07
Hi Robert,
You might try a product called NOALOX. It is a paste used by electricians to prevent corrosion on aluminum electrical connections. It's available at any electrical supply house.
I have never used it in on threaded parts but see no reason why it should not work well. It is not a penetrant so it won't loosen up a connection that is already stuck with corrosion...but it should prevent it from happening again.
Just a thought as I read your post.
Rod
another doug
03-01-2002 05:08:13
 Re: Re: Aluminum Corrosion in reply to Rod (NH), 02-28-2002 06:43:35
Robert, when i work with steel hardware in aluminum,or die cast, i use a little heat from an electric heat gun ,not a torch as bad things can happen ,but enough heat and some time to think it over as things warm up. as i understand expansion rates for steel is less than aluminum,so just a little more clearance in there makes a world of difference....go ahead and use the super advertised penetrating oil too...good luck, and don't ever forget to use anti- sieze compound when you assemble it!
another doug
03-01-2002 05:06:53
