Restoration & Repair Tips Board
Stuck Engine
Bob Parkin
02-19-2006 10:12:14
Had a Farmall Regular stuck. Went through crank case with torch and heated sleeves,worked good. Be careful not to over heat sleeve "o" rings if you donot intend to pull sleaves. Still working on loosening up cam followers.
retired farmer
02-26-2006 19:59:08
 Re: Stuck Engine in reply to Bob Parkin, 02-19-2006 10:12:14
Go to NAPA and get some spray cans of CRC carburetor cleaner and keep spraying them if you can get to them. It seems to eat rust like magic. Works without fail for me.
ejh
03-05-2006 09:38:53
 Re: Stuck Engine in reply to retired farmer, 02-26-2006 19:59:08
go get crc battery cleaner, works the best
use it all the time. dont use anything but.
had stuck motors, only thing that worked.
stuff in spray can.
