Restoration & Repair Tips Board
new holland rake repair
bob hagler
02-21-2006 20:19:23
i have a new holland rake 56 that runs when it is supposed to be out of gear i can only get it to stop running if i undu the shaft that run to the wheel. How do i fix this and what causes it
showcrop
03-01-2006 17:32:37
 Re: new holland rake repair in reply to bob hagler, 02-21-2006 20:19:23
even though mine would disengage by using the lever and cable I never towed it on the road without unhooking the driveshaft, inorder to save wear and tear on the gearbox
retired farmer
02-26-2006 19:53:30
Shifting fork might be broke off or dowel pin holding it on shaft inside of gear box. If it is like a John Deere 850 series.
boo
02-26-2006 12:15:02
Yea..like Kelly said..the cable goes to the gearbox..it can be adjusted very easily. Cable might have stretched and needs slack taken out.
Kelly Campbell
02-24-2006 05:29:35
There should be a cable that has a disengage lever for the gear box if I remember right.....The cable goes down across the back side, Might be a place to start.
Kelly
