Restoration & Repair Tips Board
Dry sleeving JD block
dawnill.
03-06-2006 16:53:39
who in Illinois will boer and sleeve my john deere D block back to stock? would like to keep org. pistons and same block any idea how much somthing like that would cost I heard new piston and rings are around $800.00 thanks for any help dawn
430WLPG
03-12-2006 15:13:59
 Re: Dry sleeving JD block in reply to dawnill., 03-06-2006 16:53:39
We had one done 6.75 D cost $500.00
george md
03-09-2006 23:12:55
Dawn, I realize that I'm way to far away for it to
be practical to ship it here , but if all else fails , I can do it . Most shops can bore A's and
other deeres of that basic size , but few shops can bore the big cylinders . standard boring bar
usually goes to about 5.4 inches , some with the
extension kit go to 6.3 and I think the D is 6.75. I have a bar with the speed reducer and a longer
micrometer , also can do it in my big horizontal
boring mill . In that machine size is almost
unlimited .
george
Jason Mills
03-08-2006 12:59:41
I had my 37 A block done this way a few years ago at a machine shop in Goreville, IL. I beleive it was in the basement of the napa store. Took them the original pistons so they could bore sleeves to match pistons. Hopefully someone else out there has had this done more recently. Any competent machine shop should be able to help you. Although there aren't that many of those blocks laying around. Good luck. Jason.
