Restoration & Repair Tips Board
Oil leaks in Oliver 1755
Brian Johnson
03-07-2006 08:01:29
I am not a restorer yet but I have a '74 Oliver 1755 Diesel(Waukesha). I have oil leaking out of left exhause manifold and out the top of the muffler. Is it a head gasket? And, if it is, how difficult is it to replace? Should I get the $60 service manual?
RustyFarmall
03-07-2006 08:13:39
 Re: Oil leaks in Oliver 1755 in reply to Brian Johnson, 03-07-2006 08:01:29
I think what you are seeing is the result of what is referred to as "wetstacking". This is what happens when a diesel engine is not being worked hard enough. You get unburned fuel going up the exhaust stack and when it cools down it just sort of drools right down the side of the muffler. The cure for this would be to get the tractor out and make it actually work, whether it is hooked up to a plow or just running up and down the road, you need to get that engine up to operating temperature and keep it there for a while. And yes, you do need a manual, in fact, you need at least three, operators manual, parts manual, and the shop manual.
