Restoration & Repair Tips Board
4430 Inj Pump
Joe Kupferschmi
03-15-2006 01:25:32
need info and diagrams and recomend places to get parts to rebuild a 4430 injection pump, also would like to mod it too. I am new to tractors and need as much info as possible
JMS/MN
03-15-2006 10:40:03
 Re: 4430 Inj Pump in reply to Joe Kupferschmid, 03-15-2006 01:25:32
Try Mike at Diesel Specialties- 800-966-2198.
the tractor vet
03-15-2006 08:44:05
Unless you have a Bacarac test stand and a couple years of exp. this is not a job for the weekend tinker. Find a good injection shop and they will do what you want but be ready to dig into the piggy bank. This is not like setting a set of plugs and points.
msb
03-16-2006 17:12:08
 Re: 4430 Inj Pump in reply to the tractor vet, 03-15-2006 08:44:05
Listen to the vet.He is giving you great advice.I was trained by Deere on those pumps.You could easily cause lots of heavy duty damage or even total destruction to those pumps if you are not trained on them.If your pump has more than 8,000 hours then it is a good bet that the barrels and plungers need replaced and a test stand is an absolute must needed to replace them.
