Restoration & Repair Tips Board
JD B paint
paul st. amand
03-15-2006 16:14:29
I am restoring a 1946 jdeere 'B',I would like to know which parts get painted yellow besides the wheels. Thanks.
SWI_Don
04-25-2006 20:47:53
 Re: JD B paint in reply to paul st. amand, 03-15-2006 16:14:29
Also the backside of the fan. Deere painted them yellow for saftey. The lettering on the axle housing is painted yellow (just the outside face) Painting all of the numbers 1-3, 2-4, 5-6 and letters H-L around the gear shift are not "original" but some people do and if you want to do it - do it.
CalJim
03-15-2006 23:05:36
Hello,
In addition to the tires,paint the "JOHN DEERE"
on the back of the rear axles,then there are the
small letters,"OIL LEVEL" on the oil cup on the
breather,the numbers on the gearshift,the timing
marks on the flywheel and gearcase,letters and
arrow on shutter knob,and the "UP" and "DOWN"
on the back of the powerlift housings,if you
have a powerlift.The rear axle shafts look good
painted a "cast iron" color. CalJim
B-maniac
03-15-2006 18:36:41
As you stand and look at the tractor from the side; Rear wheel assy.-everything you see accept the tire and axle. Front wheel assy.-everything you see accept the tire itself. I don't know of anything else on a B that is painted yellow.
