Restoration & Repair Tips Board
6V solinoid on 12V
michael price
03-20-2006 19:24:14
My uncle has a ford tractor, had a bad starter so he replaced it with a 12v. He also put a alternator on it. He still has the 6V starter solinoid and said it works fine but I said he should replace it before he gets left somplace. My question is how long will this soloinoid last running 12V through it?
michael price
03-21-2006 08:00:48
 Re: 6V solinoid on 12V in reply to michael price, 03-20-2006 19:24:14
Its a old beat up tractor, but from the looks of it Id say its a 800 or maybe a 900.
Bob
03-20-2006 23:28:50
What model Ford tractor? You can never post too much information when asking a question like this!
Some older models have a special 6-Volt solenoid, with the terminal that activates them electrically "hot".
If that is what you have, for the safety neutral start button to function, you must replace the solenoid with the same type.
John T
03-20-2006 19:38:45
Michael, it depends a lot on how long its necessary to hold the starter in before the tractor starts. If the tractor starts right up, the solenoid could last a longgggg gg time. However, if she requires a lot of cranking the solenoid could eventually overheat and suffer some damage since its coil is drawing more current then it was designed to handle. It may be possible to add an external current reducing voltage dropping ballast similar to what 6 volt coils use on 12 volt systems and it may last indefinitely. I dont see it as failing overnight from running it at 12 volts but ideally, it should eventually changed out as theyre not all that expensive.
John T
DJM75
03-21-2006 05:24:36
 Re: 6V solinoid on 12V in reply to John T, 03-20-2006 19:38:45
I beg to differ on drawing more. double the voltage and you cut the amperage in half.6V draws twice as much amperage as 12V thtas why cables are always heavier on the old 6V stuff.
John T
03-21-2006 08:33:13
 Re: 6V solinoid on 12V in reply to DJM75, 03-21-2006 05:24:36
DJM, Since I = E/R..... ...Given the SAME RESISTANCE..... . The current doubles if the Voltage is doubled like I said !!!!! !!!!! !!!!
For example, assume the solenoids DC resistance were 4 ohms. At 12 volts the current I = 12/4 = 3 amps. HOWEVER at 6 volts the current I = 6/4= 1.5 only half the current. Double the Voltage doubles the current PERIOD
NOWWWWW WWW I think what you are referring to are Motors which use current to generate an electromagnetic field and more current = more magnetic flux. The current a motor uses sees two load components, one the current used to produce the magnetic field (Inductive component) PLUS the straight DC resistance component AS IT HAS A GREAT LENGHT OF WIRE WHICH HAS SOME, ALTHOUGH LOW RESISTANCE PER FOOT. Its true that if a multi voltage winding motor were wired at 120 volts, in that case it indeed draws TWICE the current as if it were wired at 240 volts. Thats cuz the overall POWER consumed by the motor is approximately the same THEREFORE since Power = E x I if the Voltage is doubled the current indeed is halved per what you were thinking.
Nowwwww www although theres some similarity in a Solenoid compared to a motor as it produces a magnetic field which pulls a plunger, the ratio of its pure DC resistive load compared to its inductive load IS FAR DIFFERENT THEN A MOTOR, ITS MOSTLY RESISTANCE which makes my statement applicable. HOWEVER, the primary motor load is more INDUCTIVE AND LESS RESISTIVE. The motor has low DC resistance in its many many windings of low impedance copper wire VERSUS all the Inductance it has caused by multiple turns/loops of wire.
Sooooo ooo we have to make an apples to apples comparison i.e. an Inductance versus Resistance calculation to see EXACTLY the difference in current of a solenoid if the voltage were doubled BUTTTTT TTT since its ratio of Inductance versus Resistance is farrrrr rrrr different from a motor and it doesnt require anywhere nearrrrr r the inductance required by a motor (i.e. its resistance component consumes the majority of its power, it produces more heat then magnetic flux energy)
IM GONNA STAND BY MY THEORY (for now at least) lol
Thats my story n Im a stickin to it until proven otherwise. The bottom line is motors consume most of their energy in their inductance while Im sayign the Solenoid consumes much more energy in its resistive/heat component.
I thoroughlly enjoy these electrical discussions, Im NOT here to fight, but to learn things myself plus hopefully pass a few tricks onto others.
Great fun discussion, I cant wait to hear counter arguments or if anyone agrees????/
Take care yall, God Bless
John T Nordhoff in Indiana (Long retired EE)
Bob M
03-21-2006 06:21:04
Not exactly! If you double the voltage without also doubling the load resistance, the current drawn indeed will double. (Incidentally also the heat generated internally in the load - the "I squared R" - is QUADRUPLED.) This is why 6 volt rated stuff will have exactly 1/2 the resistance of the same stuff rated for 12 volts.
Proof? Take a 6 volt lamp, connect it across a 12 volt battery and observe what happens!
John T (I agree)
03-21-2006 08:34:54
 Re: 6V solinoid on 12V in reply to Bob M, 03-21-2006 06:21:04
Bob, I agreeeee eeeee lol I copied my post from above so you might read and agree or disagree also??? Love sparky chat with yall
Bob M
03-22-2006 08:22:37
 Re: 6V solinoid on 12V in reply to John T (I agree), 03-21-2006 08:34:54
Right on John T!
One minor point: Once a solenoid completes it's stroke (ie. is holding in the energized state) ALL of the energy consumed by the solenoid appears as heating in the winding.
...Bob M (not yet retired ME with a minor in EE)
John T
03-22-2006 11:24:27
 Re: 6V solinoid on 12V in reply to Bob M, 03-22-2006 08:22:37
Sheeeee eshhhhh hhh Bob, an ME PLUS a minor in EE, you can blow my doors off, I gotta watch what I say on here so you can keep me honest lol (if thats possible). I really enjoy sparky chat and the theoretical stuff, especially when we take things down to the energy level including the laws of thermodynamics and conservation of energy.
Once the solenoid is latched in, theres still an inductor and a magnetic field surrounds the windings, but not the inductive load as it takes initially to achieve the magnetic field and get current pumping, just like it takes 6 times the current to start a motor then it takes to keep it running. As we know thats cuz an inductor hates to change current which is why its impedance is initially greatest (the di/dt is present) to get her all running. I agree n well understand what you say about the load being heat producing resistance once shes latched in. The inductive reactance takes place when current initially enters the coil windings. I still see 12 volts pumping twice the current through a solenoid once the initial inductive reactance stabilizes, cuz with no di/dt (zero frequency) the loads alllll ll resistive after that.
John T (just an old Nerd n Geek n Conservative fuddy duddy)
Bob M
03-22-2006 17:44:33
 Re: 6V solinoid on 12V in reply to John T, 03-22-2006 11:24:27
Once again you're right on John T!
Geez - di/dt - it's been 35 years since I've had to wrap my brain around THAT kind of stuff! But it's also a relief to know at least some of it is filed way back in a dark corner somewhere. See....you're still way ahead of me on the theoretical aspects of all this sparky stuff! ...Bob M
jdemaris
03-21-2006 20:14:21
Just to break away from the electric theory, induction, fixed resistance, etc. - the last relay I checked in a real-world situation for pull-in current draw was as thus - hooked to 6.1 VDC it drew 1.58 amps. Hooked to 12.4 VDC it drew 3.63 amps.
John T
03-22-2006 07:07:37
 Re: 6V solinoid on 12V in reply to jdemaris, 03-21-2006 20:14:21
jd, thats good to hear and similar to what I would expect, thanks for posting it.
John T
souNdguy
03-21-2006 07:26:19
Bobm..
It's real common to see the 6v solenoid on the 12v equipment.. The 12v converted units should start faster.. thus subjecting the solenoid to less overall 'average' current.. once you figure in 'T'.
Soundguy
jdemaris
03-21-2006 06:16:05
 You're correct - but the opposite can cause damage in reply to DJM75, 03-21-2006 05:24:36
You are absolutely correct, the more voltage, the less current flow - to accomplish the same task. With a relay or solenoid, the issue is its specific ratings from the OEM company that made it. Many 6 volt solenoids - when you look at the small print of specs. - are designed to work with a minimum of 6 volts (or lower) and are often rated as high as 18 VDC. It is unlikely you're gonna' find any specs. for a used solenoid - but it's a $7 item - who cares? In my own experience, I've never seen one burn out or suffer from high voltage. I have seen many get destroyed from low-voltage. I recently made a stupid mistake and a brand new starter went up in smoke. I installed a new-old-stock diesel engine into my Case 580CK backhoe. As I said - new including all electric components. It came from a US military base. Well, it cranked slow which p*ssed me off. I had new batteries, good large cables, etc. I was in a hurry and wanted to hear the new engine run. So, I figured there was a bad connection somewhere - and I ran an array of jumper cables and more batteries. The starter just spun slow and grunted, the solenoid closed slow, etc. Finally, smoke poured out of the starter. So, I finally put my glasses on, looked close at the starter and solenoid - and it was all marked 24V. Duhh . . . ! Boy, did I feel like an *sshole. Then it dawned on me - most military stuff uses 24 volts, even their SUVs and pickup trucks. Seems their Case equipment is also 24 volt. So, I had to get an old 12 volt starter, and also find a 12 volt solenoid for the fuel-injection pump. I still feel like an idiot.
