Restoration & Repair Tips Board
John Deere 710-B pressure relief valve
Madmax87820
03-22-2006 17:22:50
I have searched every link I can think of and, well, I'm still clueless. I have a JD 710B that has Hyd. probs., I have had the pump rebuilt,(was told that it looked like new when it was apart), and still no hydraulics unless the engine is rapped up to about 2300 rpms, and even then they are sluggish. I have heard from several people that the pressure relief valve may be worn or stuck open, but I have no idea where it is located, can anyone help? Or maybe give me something else to look at besides the relief valve? Thanx
MSM
03-24-2006 00:27:10
 Re: John Deere 710-B pressure relief valve in reply to Madmax87820, 03-22-2006 17:22:50
Sounds like you have a bad charge pump in the trans,or a stuck relief valve in the filter housing,or a severe internal lube line leak.The front pump can only pump the oil that is sent to it,it does not draw it's own oil from the reservoir,the pump in the trans sends oil to the main hydraulic pump.
madmax87820
03-25-2006 18:32:32
 Re: John Deere 710-B pressure relief valve in reply to MSM, 03-24-2006 00:27:10
I am sure the charge pump is ok, the transmission works fine, I am almost sure it is the relief valve, where is it located in relation to the filter canister? Thanx a million
Glen in TX
03-23-2006 16:40:55
JDparts http://jdparts.deere.com
JD Industrial Publications for technical repair manuals or local JD industrial service manager.
