Restoration & Repair Tips Board
240U PTO Problem
Fred Vaccaro
03-24-2006 19:24:32
I have a 240 U and I just finished rotor tilling the garden and I noticed that I could not disengage the PTO. I finally pulled it off to see what was going on inside. I found that there have been problems with this unit before. The problem that I was having at this time was caused by the PTO drive shaft twisting at the front end where the splines are and not allowing the shifting tube to slide back to the disengage position. Is this a weak point on this system? Are parts available for this unit? Did I do something wrong to cause this to happen?
bil b va
03-30-2006 15:22:47
 Re: 240U PTO Problem in reply to Fred Vaccaro, 03-24-2006 19:24:32
used parts are available from a number of salvage yards . Bates Corp. 1-800-248-2955 or www.batescorp.com is the one i use the most . they are not the cheapest but have what you need as they specialize in IH parts. i suspect the rototiller is too much for your pto . there are 2 versions of the pto shaft . they have different splines . i have a 240 u .
