Restoration & Repair Tips Board
10-20 McCormick Deering valves
rgoi812
03-25-2006 03:35:49
I replaced all exhaust valves and guides in this engine due to the old were rusted and frozen in head.I used f12 valves attained from a reliable source supplier but cannot set to zero lash.question is do the rocker arm assy use a shim or shimms to elevate enough to get clearance ? This head was apart for 40+ years and after searching the several sheds on site the rocker arm assy's showed up in a coffee can but I don't know if everything was there.Can anyone tell me if I am missing something or does one just cut down the f12 valve to fit?
Jason(ma)
04-09-2006 05:13:44
 Re: 10-20 McCormick Deering valves in reply to rgoi812, 03-25-2006 03:35:49
These guys have a bunch of stuff for the 10/20 maybe they can help somehow.
ransy
03-28-2006 02:32:59
I believe that is what I will try,taking the valves out again to shorten the stem seems like a lot of work.Thanks for the reply.
Bobcat
03-27-2006 16:22:09
I would just shim the rocker arm stands up with flat washers.
