Restoration & Repair Tips Board
Ford 641 hydraulic lift problem
Lawton
03-25-2006 10:55:13
Just bought a 58 641 workmaster and the rear lift does not go up very high.When you move the lever all the way to the lift side it goes up just a little and then it will slowly bounce.It has a remote hydraulic system under the seat that is used to control the loader,would that have any effect?You don't have to be using the loader for the rear lift not to work right.The loader works fine.Any help would be great.
souNdguy
03-27-2006 11:02:39
 Re: Ford 641 hydraulic lift problem in reply to Lawton, 03-25-2006 10:55:13
When it lifts the lift.. will it do it under load or not.
If not.. might be check / relief valve.. Or could ba a unloading valve problem.
If you have a fo-20 manual, hit the hyd troubleshooting section.
Soundguy
Lawton
03-28-2006 08:39:49
 Re: Ford 641 hydraulic lift problem in reply to souNdguy, 03-27-2006 11:02:39
It will not lift with or without a load.
souNdguy
03-28-2006 10:39:41
 Re: Ford 641 hydraulic lift problem in reply to Lawton, 03-28-2006 08:39:49
I'd try to find out if you have lots of oil bypassing rear of the cyl.. if so. might be a stuck relief valve..
Soundguy
