Post Editing Available
YTSupport
06-04-2008 10:50:38
For all the on-topic forums, you can now edit your post using the modern view. The post remains editable for 30 minutes after the initial post so you can correct typos and misstatements.
Regardless of whether it was posted initially on modern or classic, if you need to make a change, click the Modern View link, then click login and do so. Go to the forum and thread involved and you will find the edit button. After 30 minutes it will tell you the time has expired for editing.
If after that period expires you need to make an important change, contact us as you would have in the past.
Please report any problems you run into.
Thanks,
Chris
Sean (TX)
06-06-2008 19:21:08
 Re: Post Editing Available in reply to Kim, 06-04-2008 10:50:38
Nice work third party image third party image....Just noticed this...Maybe it is the way it should be? The edit button is above now but it says it s to old to edit..???
YTSupport
06-06-2008 19:25:54
 Re: Post Editing Available in reply to Sean (TX), 06-06-2008 19:21:08
Yep, I forgot a couple. Todays Tractors and Yesterdays Trucks are still uneditable. I'll have to test them out first but should get that tomorrow!
Thanks for reminding me.
Sean (TX)
06-06-2008 14:33:14
 Re: Post Editing Available in reply to bannered, 06-04-2008 10:50:38
I embeded it wrong...I use a program to do it. I use HTML on some boards and BB code on others...I had no choice. Seems you can not edit in this form...The button is missing..
YTSupport
06-06-2008 14:41:26
 Re: Post Editing Available in reply to Sean (TX), 06-06-2008 14:33:14
You just reminded me. I didn't enable it on site comments. Anything below the on-topic forums I skipped except for the Test Forum which has always been enabled. It was just an oversight. There may be others.
Thanks
Sean (TX)
06-06-2008 12:30:24
 Re: Post Editing Available in reply to YTSupport, 06-04-2008 10:50:38
Looks like I cant edit my screw up here third party image
YTSupport
06-06-2008 12:39:44
 Re: Post Editing Available in reply to Sean (TX), 06-06-2008 12:30:24
Glad you mentioned that (PM). It is or at least close to next. We are getting the circuits consolidated to speed all the sites up. That's taking time but the PM is something we wanted to get going pretty fast. The big hurdle there is just making it so classic users (the majority) can easily receive them. Most of the community has never logged into Modern View so we have to bring the PM to classic.
Not sure why the edit didn't work on the picture but maybe it's because the even if you put the embedded image in on classic one way, you still have to use the img bbcode to fix it over on Modern. That's something I sorta forgot!
Thanks,
Chris
Sean (TX)
06-06-2008 12:28:25
YTSupport said: (quoted from post at 13:50:38 06/04/08) For all the on-topic forums, you can now edit your post using the modern view. The post remains editable for 30 minutes after the initial post so you can correct typos and misstatements.
Thanks,
Chris
Noticed that button yesterday...Nice work...<img src="http://scosoft.com/s/c/79731810.gif" width="25" height="18"> <img src="http://www.goboatingamerica.com/cgi-bin/ubb/graemlins/worship.gif" width="27" height="22">
What is next PM? :D
Tx Jim
06-05-2008 04:16:53
Chris,
I used your new edit feature. Worked very well, Why does it last only 30 minutes? I know you have a reason just wondering.
Thanks,Jim
YTSupport
06-05-2008 05:20:16
 Re: Post Editing Available in reply to Tx Jim, 06-05-2008 04:16:53
I think forum software limits changes because people will make a comment, get a response and then change or eliminate what they said in the first place making the thread useless. I'm just guessing though, I don't actually know all the reasons but that sounds likely.
The way the software worked by default, the minute a post was replied to, you couldn't edit it. I figured that would mean you'd never get a chance to edit on the busy boards.
Thanks for trying it out,
Chris
