Stationary Engines Discussion Forum
help with the new engine IH
Ironhorse
01-29-2006 16:53:36
jusr got a International U-240 power unit. It has a Silver diamond Engine. In getting it home several hundred miles. I broke lose every piece of rust in the gas tank. and when i got home to start it to for my wife and neighbors the new engine it didnt go. so pulled the tank and cleand out the clogs. then on to clean the carb. As usual in my hurry to hear it run again forgot how many turn in and out. So what i need is the intial adjustment on this carb and looks like three screws I know one is high speed and one idle speed and i got one on the shaft the goes between the carb and gov. the setup look like whats on the older farmalls. I got it to run but only with the choke out. that for you help and also where to get a manula for this?
thanks
Ironhorse
senlim
01-30-2006 03:10:27
 Re: help with the new engine IH in reply to Ironhorse, 01-29-2006 16:53:36
Don’t know the specific engine but going back to basics.
If the engine only runs with choke out it is not getting enough fuel. Try unscrewing adjuster screws in carby quarter turn at a time and slowly decrease choke. A bit of slow trial and error should get you going
Good luck
