Stationary Engines Discussion Forum
IHC Model M fuel pump
Jeff Allen
02-05-2006 08:15:14
Does the fuel pump for this engine have check valves in the pump itself or are they located in the lines?I recieved to pumps with this engine.one had the balls and springs in the pump and the other had a brass fitting screwed into it with a ball but no spring in it.I am going to buy a new pump as both of these are scrap.Also the carb/mixer only has two knobs to adjust on the front.Is it gas only?Thanks
