Stationary Engines Discussion Forum
Ford V8 Industrial engine
Joseph Turrisi
02-06-2006 17:10:19
I have a Smith 160 air compressor with a Ford V8 industrial engine. Can anyone help me ID the engine in this unit. The following info is stamped on the valve cover tag.
serial #18269F-5-TK
model #LSG-8751-6005-A
special options #6055
model code-HZA/6055/6BA
Tramway Guy
03-11-2006 07:34:41
 Re: Ford V8 Industrial engine in reply to Joseph Turrisi, 02-06-2006 17:10:19
The 6005 means 'Engine with flywheel and flywheel housing". But then the 'A' means 'no flywheel housing'.
The options code is special. It probably was assigned as a package specific to Smith.
Tramway Guy
03-10-2006 18:27:16
That is a the very popular 7.5Liter (460 CID) industrial engine. 173 HP @ 2800 RPM on Gasoline.
The 6005-A refers to the flywheel housing and stuff like that. I think that I have a list of some of the codes. If you want them, let me know. Any Ford industrial distributor should be able to help you with any parts you need.
Manuel in Oz
02-07-2006 22:04:05
Try here, they might know:
http://www.fordbarn.com/earlyv8/forum03/
