Stationary Engines Discussion Forum
Fuller Johnson magneto timing
Casenut
02-07-2006 19:34:35
I have a Fuller & Johnson type N 1 1/2hp with a sumter mag. I have removed the mag to be rebuilt and marked the timing. After removing the gear there are several holes that the gear can be indexed into. There is also a thin plate with pointers that fits behind the gear (mag side) The problem I have is knowing what hole is used for proper timing. Thanks in advance, Casenut
N
02-08-2006 04:37:03
 Re: Fuller Johnson magneto timing in reply to Casenut, 02-07-2006 19:34:35
On end of the gear collar there will be a stamped hash mark. On face of gear there will be a scribed line. Line up the mark with that on end of collar, one hole will line up with pin in gear. That"s the correct position.
NICK
Casenut
02-09-2006 05:58:08
 Re: Fuller Johnson magneto timing in reply to N, 02-08-2006 04:37:03
Hi Nick, Thank you very much for your info. I am enjoying your website. I have always been a Fuller and Johnson lover. I will be putting my engine in your registration soon.
