Stationary Engines Discussion Forum
massey harris f140 engine
david brugger
03-09-2006 05:08:33
i have a massey harris with a f140 engine not sure the modle of the tractor i had the crank turn and got taken to the cleaners on the main bearings i think 180.00 turn .20. i did not know about this sight. i need front and rear oil seals, the front block filler that connects to the oil panand a gasket set can anyone help
J. Schwiebert
03-09-2006 18:06:40
 Re: massey harris f140 engine in reply to david brugger, 03-09-2006 05:08:33
Your engine is an F-140 Continental. A gasket set will be available at any good parts store. If you need set numbers I can furnish. You will need to order the timing cover gasket seperate. There were probably a half dozen different front covers because of all the lift truck applications. I would check for the aluminum block at a good Continental distributor or a good fork lift shop. At one time that F400 series Continental was the most popular lift truck engine on the market. Questions?
