Stationary Engines Discussion Forum
timing a vg4d wisconsin engine
fireball001
03-16-2006 22:25:51
I have an older skid steer with a Wisconsin vg4d engine. I need to time it but there are no marks on it to determine where top dead center is. Any advice?
Delbert Fisher
06-30-2007 09:08:31
 Re: timing a vg4d wisconsin engine in reply to fireball001, 03-16-2006 22:25:51
I need to know info on how to time a wisconsin magneto to the engine of 4g4d. thank you
fireball001
03-18-2006 15:54:58
When I look at the flywheel, I am able to see a D and a C stamped on it. But the housing has no marks at all. Thanks for telling me about where to look on the flywheel. Any suggestions where the mark would be on the housing?
Bob
03-18-2006 22:47:31
 Re: timing a vg4d wisconsin engine in reply to fireball001, 03-18-2006 15:54:58
The marks should be lines lightly marked into the flywheel housing tin right next to the big opening where you see the flywheel, IIRC, to the left of the vertical centerline of the engine, aligned with the centerline of the LH cylinder bores, as viewed from the flywheel end.
If you can't see them, I will try to take a look at a VG4D I have stored in an old shed, and verify this. Also, I have some old manuals, if I can find them. I could scan a drawing, and email it to you.
bigcoulee@hotmail.com
Dave from central Pa
07-31-2006 08:27:25
 Re: timing a vg4d wisconsin engine in reply to Bob, 03-18-2006 22:47:31
Can you help with tune up specs. for a VG4D engine?
I need point gap; timing order, cylinder order, and timing info. (How many degrees Befor or after the mark and what location of mark?)
Thank You for any advice
Bob
03-17-2006 07:03:13
The marks are on one flywheel vane, and on the steel flywheel housing.
