Stationary Engines Discussion Forum
Wisconsin TJD Engine flywheel
Jason Froehlich
03-30-2006 18:46:09
Hi does someone know how to remove the flywheel on a wisconsin tjd no place to put a puller Thanks for any help Jason
Gene Davis (Ga.)
04-14-2006 20:41:23
 Re: Wisconsin TJD Engine flywheel in reply to Jason Froehlich, 03-30-2006 18:46:09
If you have only one cooling fin or vane as you refer to it broken off, you can break the one directly opposaite it off and continue to run the flywheel as it will be pretty well balanced like this.
ROBIN68
04-01-2006 02:49:03
JASON
You have to unscrew the nut 2 or 3 turns just for the nut to arrive at the cranshaft end of pitch. The best is to have another person to help.
One holds the flywheel with the two hands and the other hit with a special hammer (copper soft hammper, I don't know the name in English) on the nut so that the cranskahsft stud is not damaged. Flwyheel should come out
Jason Froehlich
03-30-2006 19:17:14
also found a vane busted off we will be looking for a good used flywheel for it it has electric start and has flywheel alternator Thanks Jason Viking62@tennesseetel.net
