Stationary Engines Discussion Forum
3-5 HP IH LB
Thomas Windsor
04-04-2006 18:05:57
I have a 3-5 HP LB. I have rebuilt the thing and am having trouble with the fuel system. Is there anyone here that is a fuel management expert on the LB or maybe you can suggest someone.
Bison
05-01-2006 17:04:44
 Re: 3-5 HP IH LB in reply to Thomas Windsor, 04-04-2006 18:05:57
What is the problem?
One sugestion. check the checkvalve in the tank where the suction tube connects, it could be stuck or rotted out.
Tom Windsor
05-01-2006 19:16:33
 Re: 3-5 HP IH LB in reply to Bison, 05-01-2006 17:04:44
I have a tank that mounts up high on the front of the motor. I have now solved the problem. Thank you for your response. As it turned out, I was getting adequate fuel but was having a spark problem. I reduced the gap on the plug and it runs great. Thanks.
