Stationary Engines Discussion Forum
Compression Test on Cummins Diesel
Steve-Maine
04-09-2006 09:09:45
I would like to do a compression test on a Cummins 4B3.9 Diesel. I can browwer the adapter to use a compression gauge. How many pounds should it show? Just rebuilt engine and am getting unburnt fuel out exhaust. I have had pump and injectors rebuilt but that didn't help. I talk to Cummins dealer and they don't do compression tests. They were talking about a blow by test which I didn't understand. Thanks for any help.
Tramway Guy
04-12-2006 18:16:13
 Re: Compression Test on Cummins Diesel in reply to Steve-Maine, 04-09-2006 09:09:45
Maybe it just needs to be broken in after rebuilding. It will take several hours of operation.
jrs
04-11-2006 12:53:47
When you say unburnt fuel what do you mean? Is fuel running out the exhaust or do you just see heavy black smoke? White smoke is incompleat combustion,black is heavy fuel compaired to the air ratio.the amount of air to the amount of fuel.White smoke could also be from late timing,some diesel will retard the timeing during warmup.Natural asperated engines relay on air being sucked into the engine where as the ones with turbo charges get a boost from the turbo charger. 2 cents worth
Steve-maine
04-11-2006 14:48:13
 Re: Compression Test on Cummins Diesel in reply to jrs, 04-11-2006 12:53:47
The exhaust outlet is damp looking, feels like fuel. No smoke of any kind. Did a blowby test today and couldn't really find anything wrong. The other 2 Cummins I just rebuilt have a little soot in the exhaust pipe. Maybe I'm just fussy but am getting ready to sell it. Don't want any problems down the road. thanks
Bob
04-09-2006 09:21:06
I would GUESS 400 to 500 PSI. What is even more important is the consistancy of compression pressure between a 4 cylinders, within 5%, or so. What numbers are you seeing?
Steve-Maine
04-09-2006 16:33:29
 Re: Compression Test on Cummins Diesel in reply to Bob, 04-09-2006 09:21:06
BOB, Thanks for infor on Leakdown Tester, I going to make one this week.
Steve
Steve-Maine
04-09-2006 10:16:56
I haven't done it yet as my gauge only goes to 300, I'l have to borrow a gauge that will go higher. Have you ever heard of a blow by test? Thanks
Bob
04-09-2006 12:04:12
 Re: Compression Test on Cummins Diesel in reply to Steve-Maine, 04-09-2006 10:16:56
They're either talking about measuring the positive crankcase pressure (caused by blowby) with a manometer, or about a cylinder leakdown test.
Here's a link to a site where a guy built his own leakdown tester for a gas engine, but the principle would be the same for a diesel.
