Stationary Engines Discussion Forum
Briggs flywheel sheer keyway
Tom/Idaho
04-16-2006 11:25:39
5 hp Briggs model 13202 is on a rototiller. Sat outside a couple years. Cleaned the carb, put on a new tank and cleaned the flywheel. Started right up and ran very good. Would'nt start the next day and I found the flywheel sheer pin was broken. Bought a new pin and torqued the ratchet/nut down to 60# (per the book) Started and ran great. Next day it sheered the shear pin again. The crank shaft is smooth as is the inside of the flywheel (no burrs). And I put the washer between the flywheel and the rachet/nut. Anyone has an idea as to what would cause this? The motor runs very good when it runs. Thanks for any suggestions, Tom/Idaho
Tom/Idaho
04-17-2006 05:24:50
 Re: Briggs flywheel sheer keyway in reply to Tom/Idaho, 04-16-2006 11:25:39
Bob, thanks for your suggestion. I will do it today. Tom/Idaho
Bob
04-16-2006 14:19:01
Engines that direct drive a lawn mower MUST have the soft flywheel key to give the crankshaft a CHANCE at survival if the blade hits an obstacle. On a tiller, an iron key could be used.
I have heard of guys scuffing up the crankshaft and flywheel hole a bit with sandpaper or emery cloth, then assembling the flywheel to the crank, and tightening it up.
