Stationary Engines Discussion Forum
Kohler charging coil
Gene Davis (Ga.
04-23-2006 13:29:38
Anyone out there know the parts number of the 3 amp charging coil for a K181 Kohler Engine. The magneto coil on this engine died and i put a 12v battery ignition coil on it to fire the ignition, but now I need a charging coil to allow the alternator to charge the battery. The Kohler website shows 2 alternator stators used one is a 3amp which they show as NLA, and a 1.5amp stator. The 1.5 will not supply enough to recharge the battery from cranking the engine and firethe spark coil at the same time. Any body got a good used charging 3 amp or larger charging stator coils for sale out there? Any advice or suggestions are welcome. Gene Davis
