Stationary Engines Discussion Forum
Engine and transmission Identification
The Parsons Fam
05-06-2006 06:35:53
HELP! We have an engine and transmission and need help in figuring out what kind it is. The only identification helpers are the following: serial # on the steel engine id tag is 18v883ael048863, Mowog, 1800cc, Lucas, and a Napa Gold Oil filter #1068. We have had two different people look at it and one says it is a Ford 8N, and another says it is a Massey Ferguson!
JoeK
05-08-2006 10:03:40
 Re: Engine and transmission Identification in reply to The Parsons Family, 05-06-2006 06:35:53
18v883 model engine no corresponds to appx late 70s MG 4cyl auto engine.Most"tractor"engines such as Ford 8N or Fergeson would be easily IDed by the"stock"clutch/trans housing being designed as an integral part of the tractors chassis,unlike the small case used for automotive trannys.The exception would be a tractor engine set up for stationary use.
JV
05-07-2006 09:12:44
If it's got MOWOG (MOrris WOlseley Garages)on it anywhere then it's BMC for certain. 1800cc would make it one of the "B" series petrol engines. AS someone else said a pic or two would be handy.
Cheers, JV.
Kent of SW MO
05-06-2006 13:00:35
With the displacment listed in cc and Lucus electrics I would think British made.
Kent
Bob
05-06-2006 09:09:51
That filter is a spin-on oil filter, and an 8N would NOT have a spin-on oil filter (unless someone has made up a changeover) Lucas electricals would also point away from an 8N, at least if you're in the US.
How about a picture... almost certainly SOMEONE will recognize it!
