Stationary Engines Discussion Forum
Wisconsin VG4D
appengineer
06-07-2006 09:24:56
VG4D, propane/nat gas, magneto, direct drive pulley ... run very little. Originally on generator. Will run ... although hard to start. What"s it worth?
Tramway Guy
06-15-2006 14:10:04
 Re: Wisconsin VG4D in reply to appengineer, 06-07-2006 09:24:56
What is the casting number on the cylinder heads? I might be interested in the engine..if it has the LP heads.
Glen in TX
06-13-2006 14:11:52
What was it off of? Does it have clutch on it? If you are close to Friona, TX I might be interested.
senlim
06-08-2006 20:51:23
No idea on value, however, VG4D is hard to start if the wrong (THD, VH4D, VF4D) crank handle is used. The VG4D crank handle is about 50 mm longer than the THD etc crank handle.
Good luck with the sale
Senlim
appengineer
06-12-2006 04:36:55
 Re: Wisconsin VG4D in reply to senlim, 06-08-2006 20:51:23
Senlim,
Thanks for info. The unit is 12v starter equipped. The starting issue appears to be related to correct gas pressure which has required some tweaking.
I"m selling the engine to replace with 2 cyl/ohv gasoline drive.
Thanks
DKL
