Stationary Engines Discussion Forum
5 HP bs
vjd
06-12-2006 19:20:20
Ihave a 5HP B&S moter vertical shaft mower it starts and runs until you try to move it then it just stops running if you get on the choke in time you can keep it running What is wrong and where do I start to fix on this?
vjd
06-13-2006 15:16:24
 Kent of SW MO or any one else in reply to vjd, 06-12-2006 19:20:20
that screw does not make any difference where I put it, it starts and runs but when you move it it[the mower] will quit running it a 5HP I put a new fuel pump in it too and boiled out the carbuator with no help vince in S.D.
Kent of SW MO
06-13-2006 06:18:23
 Re: 5 HP bs in reply to vjd, 06-12-2006 19:20:20
Try opening you mixture screw a little.
Kent
