Stationary Engines Discussion Forum
ihc type lb stationery engine imfo
frank in sask
06-17-2006 21:06:13
I purchased a running IHC type LB engine at an auction today. First time I had one. Ser.#LBA 142921 What year would this have been manufactured. Also what is the proceedure for starting and any other imfo I should know. Frank
huntingreen
06-28-2006 21:30:11
 Re: ihc type lb stationery engine imfo in reply to frank in sask, 06-17-2006 21:06:13
I can tell you if it is a LB it was made between 1941 and 1948. Open the gas adjustment about 3/4 turn. Push the choke down and give her a crank. There is a check valve on the end of the fuel line in the tank. You might take it out and make sure it is free. Hit and Miss Enterprises has about any part you will need.
