Stationary Engines Discussion Forum
Oil on Tapered Fit
ERT
06-20-2006 10:55:31
In the Wisconsin parts post below there is mention of NOT using oil on the taper fit of a flywheel. I have always used a light film of oil on tapered shafts thinking I was doing the right thing. Have I been flirting with disaster all these years?
senlim
06-20-2006 18:48:02
 Re: Oil on Tapered Fit in reply to ERT, 06-20-2006 10:55:31
It was my post so I will start off with the rational for the comment.
Oil is applied to metal to metal contact surfaces for lubrication and to prevent actual metal to metal contact where 2 surfaces slide over each other as in bearings, pistons, pins and bushes etc. When the lubrication breaks down the two metal surfaces touch and cause heat through friction. This can result in minute friction welds that break off and start the crazing seen on failed sliding components or the ultimate disaster of seized components that friction weld themselves together.
On a taper fit coupling movement is the last thing required. The two taper surfaces are forced together by the clamping nut to prevent movement. I know the lubrication may help future disassembly but I have seen expensive crankshaft and flywheel damage on large slow revving diesel engines caused by flywheel chatter attributed to the shock torque load of compression ignition on these components when an engine is working hard. Minute black particles, typical of burnt oil, were often seen in the damage area.
OK, other comments please I am not too old to learn.
Senlim
ERT
06-21-2006 09:54:32
 Re: Oil on Tapered Fit in reply to senlim, 06-20-2006 18:48:02
Great explanation. I guess I have avoided problems because the rotating parts have been relatively light and at low RPM. Would you ever consider using an anti-seize compound on a taper or would that be worse than oil?
Senlim
06-21-2006 17:18:47
 Re: Oil on Tapered Fit in reply to ERT, 06-21-2006 09:54:32
I guess the only place I would consider an anti-seize on a taper joint would be in a harsh (chemical or marine) environment where there is high risk of corrosion. Again in these environments non-corroding metals would be a better choice.
Senlim
