Stationary Engines Discussion Forum
3-5 HP IH LB engine
Tom Windsor
06-25-2006 19:02:49
I have a 3-5 HP LB engine here. I recently acquired it at auction. I pulled the head and found that the cylinder wall has exfoliated and there was a handfull of rust in the cylinder. It will not, after getting it unstuck, run. It looks to me like it will require a sleeve or oversized piston. Does anyone have any insight into this particular engine and any suggestions as to how to cure the bad hole???
Tom
Will/ MN
07-04-2006 12:55:15
 Re: 3-5 HP IH LB engine in reply to Tom Windsor, 06-25-2006 19:02:49
The 3-5 is a very common engine. Probably easier and cheaper to find a good used block. Do you have any compression at all? Did you install new rings?
