Stationary Engines Discussion Forum
wisconsin VE4D mag timing marks
Anderson
07-18-2006 19:49:22
I need help on finding the timing mark on my engine for the mag I can see the one on the mag but when I look on the gear that runs the mag I cant find a mark is there a mark or not.
senlim
07-18-2006 21:06:17
 Re: wisconsin VE4D mag timing marks in reply to Anderson, 07-18-2006 19:49:22
There should be a mark in the tip if one of the magneto gear teeth not on the face of the gear.
It is usually a “x”.
Good luck
Senlim
Senlim
07-18-2006 21:12:24
 Re: wisconsin VE4D mag timing marks in reply to senlim, 07-18-2006 21:06:17
Sorry miss read your post the first time.
The mark is on the flywheel and flywheel shroud. On the flywheel in line with the keyway and on the shroud at about 10:00 o’clock. Fit the mag after assembling the rest of the motor with the "x" in the hole on the side of the gear cover.
Regards
Senlim.
