Stationary Engines Discussion Forum
Wisconsin VE4
Anderson
07-27-2006 19:16:13
I just got my VE4 wisconsin running but one cylinder wont fire it has spark and it is getting gas the valves arent stuck there is nothing blocking the intake and I addjusted both valves to 20 thounadths of an inch put new mag cap on and new copper wire plug wire and it still wont fire if anybody knows what to do let me know.
Tramway Guy
07-29-2006 06:08:23
 Re: Wisconsin VE4 in reply to Anderson, 07-27-2006 19:16:13
Are you sure it's not working? The VE4 has an uneven firing order, so it always sounds like it's 'missing'...how do I know? Because I had a VF4D engine that I thought wasn't firing. I took both heads off and was stumped until I noticed that the distributor cam wasn't square. Then I investigated further and found out why.
The VE4 is similar, except with the magneto, the mag fires twice as often as most engines.
n9lhm
07-28-2006 10:44:20
Plug fouled? While running, put on a glove and pull the wire off the spark plug. Hold it about 1/8" away from the plug terminal, so the spark has to jump two gaps, and see if the cylinder then starts to fire. If so it"s the plug.
