Stationary Engines Discussion Forum
Maytag 92
H fanatic
09-04-2006 19:34:55
hello,
I have a maytag 92 and I have a problem. It will only run if you put your two fingers over the air intake hole every once and a while, to choke it. What could cause this? I have heard that it needs a check ball in the fuel pickup tube. (it doesn"t have one) If that could cause it where can I find one? or can I improvise? What else can I try to fix my problem? Thanks Nick
fzbcheve
10-30-2006 17:48:38
 Re: Maytag 92 in reply to H fanatic, 09-04-2006 19:34:55
Briggs & Stratton engines with the suction, carburetors,(used on a lot of lawnmowers) the one's with only one suction tube, use a ball foot valve. They are readily available from most B/S dealers.
Tinker In TN
09-04-2006 20:11:09
Go to www.maytagshed.com
