Stationary Engines Discussion Forum
U 21 IHC ?
Duner Wi
09-25-2006 05:19:44
Have a U21 6 cyl. gas with mag. Would like to know the bore,stroke and HP at 1950 rpm. The block is stamped UHM and the U21 is on the plate on bell housing.
What were these units used on 65 years ago? This one is on a Snogo.
Any info appreciated.
noncompos
09-29-2006 11:06:00
 Re: U 21 IHC ? in reply to Duner Wi, 09-25-2006 05:19:44
Wellll... here"s a little info..
51 Gates catalog shows U21 as 1932-49 (no b/s or usage)(shows var other IHC thru 50).
50 Fed-Mogul bearing catalog is little more help: shows U21 lumped in with other engines that take same rod/mains, with the two b/s"s: 35/8x41/2 AND 33/4x41/2, with no way to tell which was which, and no usage shown. Neither have any serial # info.Hopefully someone else will have more. Good luck.
Duner Wi
09-30-2006 20:22:35
 Re: U 21 IHC ? in reply to noncompos, 09-29-2006 11:06:00
Thank you very much for the info. This is a great help. I am guessing the U21 is the FBB298 or possibly the FBB279. Thanks much.
