Stationary Engines Discussion Forum
3-5 HP LB engine.
tom Windsor
10-23-2006 22:01:25
Does anyone have a picture of a 3-5 hp engine with the radiator. I am needing to see how the fan and the radiator work together. I got pieces but cannot figure how they work. Need to see if there is duct work from fan to radiator..and what it looks like if there is such things.
Tom Windsor
Vacherie
11-03-2006 18:42:52
 Re: 3-5 HP LB engine. in reply to tom Windsor, 10-23-2006 22:01:25
Did you get the information on the duct work. I have most of the duct work and could help if you need it.
KevinH
10-30-2006 15:49:23
Hey Tom, Check your email...
Kevin
the Unforgiven
10-24-2006 06:03:59
Hey Tom, get on enginads.com, go to the Smokstak, and post the same question. Bill
olelon
10-24-2006 20:10:01
 Re: 3-5 HP LB engine. in reply to the Unforgiven, 10-24-2006 06:03:59
owned a couple of these engines in the past they were uses on a haybaler. I still have the baler, the engine had a shroud on it to help circulate the air. Dont know what happened to the shroud it was made of sheet metal and mostly rusted away.
Tom Windsor
10-30-2006 20:45:15
 Re: 3-5 HP LB engine. in reply to olelon, 10-24-2006 20:10:01
I sure would like the rusted out stuff to use as a pattern.
Tom Windsor Twindsor@aol.com
