Stationary Engines Discussion Forum
Lister LD1 - Changing RPM
Kent F Mapes
11-04-2006 18:01:18
I have a Lister LD1 which is set at 1500 RPM presumably to run a generator or the like. I have set the engine up n a pump however the revs are too slow to pump sufficient water. If I fit a larger pulley to the motor I feel the engine will stall at the lower revs. Is there anyway to adjust the revs higher without going to great expence.
steve from mo - dangit!
11-08-2006 06:55:41
 A manual? in reply to Kent F Mapes, 11-04-2006 18:01:18
Link
