Stationary Engines Discussion Forum
HOW DO I REPAIR CYCLINDER
BART HAVENS
11-18-2006 19:24:02
I HAVE A 2HP WHITTES AND THE CYCLINDER IS WASHED OUT ON THE BOTTOM THRID BY ABOUT .010 . HOW DO I FIX THIS ? IF I BORE IT .020 TOTAL OR .010 PER SIDE CAN I PUT OVERSIZE RINGS IN IT ? HELP !
BART
ken in texas
11-21-2006 13:35:15
 Re: HOW DO I REPAIR CYCLINDER in reply to BART HAVENS, 11-18-2006 19:24:02
First you need to contact a good automotive machine shop and have your cylinder and piston measured for wear.Should be able to bore it and fit a sleeve the correct size to fit piston.May need a new piston or have it built up and machined to fit. Rings have to fit piston size.Can not just use oversize rings on old piston.
Bob
11-19-2006 03:37:33
Bore it and sleeve it back to standard size...
Bore it, and have the piston built up accordingly (flame spraying)...
Bore it, and locate an OS piston...
