Stationary Engines Discussion Forum
Low Oil Switch On 10HP Tecumseh
BobInMN
01-01-2007 15:12:20
I've got a 10HP Tecumseh on a generator. The on/off switch on the engine will start flickering while the engine is running. The engine is full of oil. On the bottom of the engine there is a small plate that is held on by 4 torx screws. Can I take this plate off to check the switch without draining the crankcase? Until today the engine hadn't been run for over 5 years. I'm assuming that my low oil shut down switch is probably bad.
MLP
01-02-2007 08:27:42
 Re: Low Oil Switch On 10HP Tecumseh in reply to BobInMN, 01-01-2007 15:12:20
The low oil switch protrudes in to the crankcase so if you pull it when it is full of oil it will drain to the bottom of the switch hole. You can pull the wire off of the low oil switch and see if it runs better. They will run just fine with the switch not hooked up. It just will not inhibit the starting if the oil is low.
