Stationary Engines Discussion Forum
continental R series engine
davids
01-14-2007 20:06:22
A continental "R" series engine model R14. What is the head bolt torque,rocker arm stand bolt torque and the valve clearance? Any help is appreicated. Thanks, davids
noncompos
01-17-2007 14:34:33
 Re: continental R series engine in reply to davids, 01-14-2007 20:06:22
If you haven't gotten the info you need,what year is that, or what's it in? I find lots of Cont R's, but no R14 (either it's in something my stuff doesn't cover, too new or you're misreading the ID tag).
davids
01-17-2007 18:24:20
 Re: continental R series engine in reply to noncompos, 01-17-2007 14:34:33
Its in a sewer pump/blaster/jet and by FMC. If you go to contential's web site it shows a pic of it. Two models offered; a R10, 1 litre and a R14, a 1.4 litre. Cast iron block, alum. head with the water pump bolted to the head. Valves in head w/ cam in block. Intake and exhaust manifolds are cast together. Distributor,fuel pump and oil filter are on the left hand side. Hope this helps. Thanks,davids
