Stationary Engines Discussion Forum
163 Continental Oil Pump diagram
Frank656
01-27-2007 09:39:33
Does anyone have a copy of a F163- Continental oil pump diagram? Or how to remove it from the engine?
Shovelman
01-30-2007 05:34:52
 Re: 163 Continental Oil Pump diagram in reply to Frank656 , 01-27-2007 09:39:33
We just did a ring job on our old Lincoln welder with an F-163 and the pump came out with just a little gentle prying.
The book shows no other styles of pump mounts, so John's recommendation of a little tapping with a brass drift may be in order.
Good luck,
Scott
J Schwiebert
01-28-2007 09:38:10
Huh? Did you remove the distributor and the drive shaft first? I can look in My Continental manual but I don't recall any special instructions.
FB60462
01-28-2007 12:41:51
 Re: 163 Continental Oil Pump diagram in reply to J Schwiebert, 01-28-2007 09:38:10
I pulled the distriutor out & I took 1 nut off the the oil pump. The pump will move from side- to- side but will not drop down.
J Schwiebert
01-30-2007 04:04:28
 Re: 163 Continental Oil Pump diagram in reply to FB60462, 01-28-2007 12:41:51
It has been 10 years since I worked on an F model Continental, but the last one was all stuck and we taped with a long brass drift through the distributor drive opening. Good Luck. J.
