Stationary Engines Discussion Forum
Model E bearings
Maark
02-08-2007 17:04:10
1 half of the main bearing have a groove with 2 holes in them. Do they go on top of the crank or below the crank? Thanks..
NE IA Dave
02-13-2007 16:17:46
 Re: Model E bearings in reply to Maark, 02-08-2007 17:04:10
Being you have it apart some guys cut screw threads so as it runs it screws the oil back into the crankcase. Those are noted for building up pressure as well as just throwing oil. I did not do that to mine, and it does throw a little oil however not to bad.
Maark
02-11-2007 16:54:10
Thanks...
Larry from md
02-09-2007 14:29:04
The holes and grooves are for the oil or grease used so that would put them on top.
