Stationary Engines Discussion Forum
wisconsin-robin 390
Bill Gearing
03-15-2007 16:07:56
Help have a JLG little john with 390 enginine have had trouble with this for years also looking for an air cleaner element that will fit correctly. the problem is the thing runs for about 20 minutes and then quits it is worse in hot weather. this last time it failed to star again. usually after it sits for 15 minutes or so it starts back up. it also backfires out of the carburetor. oil is fine. spark is fine. and it has compression
senlim
03-16-2007 13:46:59
 Re: wisconsin-robin 390 in reply to Bill Gearing, 03-15-2007 16:07:56
The symptoms you describe sound like a failing ignition coil or condenser. The spark needs to be able to jump 5 to 7 mm and be a good fat blue spark. If it is orange change the condenser.
Good luck
senlim
