Stationary Engines Discussion Forum
IHC LB frozen governor
Steve54
03-31-2007 11:50:39
I just got a restored International "LB" 1-1/2 to 2-1/5 HP engine running. The governor is not working because the butterfly valve is is stuck. The rod running through the block to the crank case is frozen.Anyone had any experience on getting that thing unstuck without destroying it? I can even turn the butterfly valve plate to remove the screw in it. Do I have to remove the cylinder head to get it out? Thanks for any help. Steve
Steve54
03-31-2007 19:00:39
 Re: IHC LB frozen governor in reply to Steve54, 03-31-2007 11:50:39
Never mind. I finally got it! Lots of PB Blaster penetrating oil and delicate tapping with a hammer and screwdriver finally loosened it up without breaking it.
