Stationary Engines Discussion Forum
Clinton Point Gap
OLDCLINTON
04-04-2007 18:18:58
I have an only 60s model Clinton single cylinder 3 3/4 HP push mower, right? (I like fixing up old mowers) Well, I am getting spark about 8 times out of 10, and need to be getting spark every time. I replaced the coil with a brand new Techuseh coil, it fit perfect. I need to know what the gap would be between the flywheel, and the coil. Also, I need to know what the point gaps would be. Thanks!
fzbcheve
04-13-2007 18:23:14
 Re: Clinton Point Gap in reply to OLDCLINTON, 04-04-2007 18:18:58
Some of those Clinton points had a riveted contact that got loose with use. Try an other set of points.
Kent of SWMO
04-05-2007 15:58:02
Most all small engine mags use .020 inch point gap. Many Clintons had a little projection on the cover that went over the points that you used to adjust the point gap. Many had an arrow that pointed at this projection that said .020". I do not think you can adjust the gap between the coil laminations and the flywheel. The lamination mount on a shoulder onthe block that is around where the crankcome through. Check the flywheel side main bearing for play. It may be loose which can cause the point gap to vary.
Kent
OLDCLINTON
04-05-2007 17:04:41
 Re: Clinton Point Gap in reply to Kent of SWMO, 04-05-2007 15:58:02
Thanks for the reply. I'll have to try this tomorrow as it is snowing right now :(. Thanks though!
