Stationary Engines Discussion Forum
Gladden timing
Gladden aa
04-09-2007 19:23:54
I took my Gladden BB 3HP apart (with a hammer and chisel) without checking for timing marks since i didnt expect to put it back together, now i am ready and i dont know the timing. There is no visible marks on the cam gear, but one the crank gear there are two "w"s with a circle around them, one on a tooth beside one and other, located a few degrees behind the crak pin and there are two center punch marks one the rear counter weight also, any help is appreciated.
senlim
04-09-2007 22:23:07
 Re: Gladden timing in reply to Gladden aa, 04-09-2007 19:23:54
I am assuming this is a 4 cycle engine.
A general rule of thumb for most engines is that the inlet and exhaust valves will overlap on Top dead center at the end of the exhaust stroke and beginning of the inlet stroke. Thus if you assemble the timing gears so that as the inlet opens and the exhaust closes as the crank goes over TDC you will have a good valve timing.
If there are no other posts with more detail this may be of help.
Good luck
Senlim
Gladden aa
04-12-2007 18:31:46
 Re: Gladden timing in reply to senlim, 04-09-2007 22:23:07
thanks Senlim, i'm gonna give it a try this weekend, i'm gonna use an old wisconsin engine as a model if i run into trouble, gladdens and wiconsins are very similar in design
