Stationary Engines Discussion Forum
worthington air compressor engine id
in sticks
05-02-2007 15:07:13
third party image
have what is a worthington air compressor trailer mounted model 160.engine is a 4 cyl gas liquid cooled.tag for engine id is missing.there are some raised numbers on carb side of engine which might help to id engine. Q256400E CWD B189
dist is a PRESTOLITE IAD-6003-2J11A
carb is a MARVEL-SCHEBLER TSXU 838 75N
hopeing some one can help id the engine as it needs a water pump and maybe rod and maine bearings thanks for any help
george md
05-09-2007 18:51:28
 Re: worthington air compressor engine id in reply to in sticks, 05-02-2007 15:07:13
third party image
This is the G 2000 that I have apart now.
george
Glen in TX
05-08-2007 18:12:33
The MS carb TSXU-838 is a universal TSX carb and that is why the U after TSX. There were several TSXU carbs made for many applications.
Prestolite parts catalog shows the IAD-6003-2J distributor as a 4 cylinder for J.I. Case applications. IAD-6003B for Cockshutt/Hercules and IAD-6003D Hercules. IAD-60021C dist. was for a 6 cyld. Worthington pump. Distributors may have been close enough and switched from another engine?
I'm not saying George is wrong but just stating that is what manuals show from the carb and dist. numbers. Have no idea on the block number but I bet George does.
george md
05-02-2007 20:10:41
My guess would be a hercules G 2000 , parts are
somewhat scarce. I have one apart now and need
governor parts and pierce no longer services
that one .I"m trying to find enough pieces to
build one . I think rings , bearings , and
gaskets are the only things available for it.
george
