Stationary Engines Discussion Forum
Maytag twin upright?
Alaskanrocket
05-14-2007 16:14:39
Has anyone ever seen sombody turn a 72 twin into a single upright? Is there any info on this at all? I guess what I'm mainly looking for is a couple reference photos and what to use for a flywheel. Thanks, Jess
ken in texas
05-15-2007 10:24:19
 Re: Maytag twin upright? in reply to Alaskanrocket, 05-14-2007 16:14:39
After checkin my Maytag twin,Ican't help you. It looks like it might require some machine work.Don't know what else to tell you . Sorry???
Tinker IN TN
05-14-2007 20:32:55
Use the original flywheel.
ken in texas
05-14-2007 19:22:12
One thing for sure is to use the orginal flywheel for the ignition.
ken in texas
05-14-2007 19:18:58
Yes I have seen one of those,the best I can remember one cylinder and piston and rod is removed and a plate made to bolt over the open crankcase.The second cylinder is rotated to point up.Now I have drawn a blank??? I might try looking at my Maytag tommorow and see if it rings a bell. I have thought about that conversion but havent tried it so far...
Alaskanrocket
05-17-2007 18:48:36
 Re: Maytag twin upright? in reply to ken in texas, 05-14-2007 19:18:58
Well I was thinking about running it on a mini low tension coil and using a valve wheel for the flywheel. It would require a little machine work to the crank and I would have to balance the valve wheel but I think it would work. As far as the crank case goes My thoughts were to cover one crank end with a plate like somebody said earlier. Well Thats my thoughts anyways. Jess
