Stationary Engines Discussion Forum
Problem with Linamar/Onan engine
KRUSS1
06-02-2007 12:36:21
I've got a Linamar/Onan 990LX 24 hp two cylinder engine that powers the fan on my air seeder. It starts right up like it should, but after about 3 minutes it starts to slop oil out of what I assume is some sort of a refief valve on the back side of the fuel pump. Replaced fuel pump with a known working one. No fix. What now? Any suggestions welcome.
Bob
06-02-2007 16:21:00
 Re: Problem with Linamar/Onan engine in reply to KRUSS1, 06-02-2007 12:36:21
Is it a camshaft-driven "automotive-type" fuel pump, as opposed to a diaphragm pump operated by crankcase pressure pulsations?
If it is a cam-driven fuel pump, the oil is probably leaking out of a "weep hole" that is there to let gas leaked through a ruptured diaphragm leak externally, instead of into the crankcase.
If the fuel pump you "subbed" does NOT leak on another engine, I would suspect a clogged-up crankcase ventilation system, or perhaps the engine simply has massive blowby from bad piston rings/cylinder walls from eating too much field dirt. We used to see that all the time on engines on granular applicators.
KRUSS1
06-06-2007 07:25:30
 Re: Problem with Linamar/Onan engine in reply to Bob, 06-02-2007 16:21:00
Solved the problem!!! Collapsed bresther hose. Always look for the simplest solution I guess.
Bob
06-07-2007 10:26:48
 Yeah! in reply to KRUSS1, 06-06-2007 07:25:30
Glad that worked out for you!
