Stationary Engines Discussion Forum
Cunningham model EB timing
flic50
06-11-2007 17:47:19
Hello all, I have a Cunningham EB engine, and I am having some trouble getting it timed. It has an adjustable timing on it, I am told like a techumsah. Not only can the points be adjusted, but the coil can be rotated so it adjusts when the magnets on the flywheel hit it (the mag is behind the flywheel). Does anyone know how to set the coil contacts properly? I get spark, and I get smoke when I pull it over, but it will not run. This has a couple of us stumped. Thank you all for your help.
- Mike
