Stationary Engines Discussion Forum
IHC LA engine trouble!
H fanatic
06-17-2007 18:33:41
Hello,
I have a IHC LA with a Wico AH magneto, and I can"t seem to get it running. Is the timing procedure different for a LB? Because my friend has a LB and his sparks before the DC mark gets to the timing mark on the side plate. And his runs great. Does anyone know how to index the governor on a LA. Because I heard if you take the head and carb off you will have to index the governor in order to make it run. Is that true? Because I had taken the head off to change rings I also changed the governor gear. I am just confused out of my mind! Please HELP Thanks,
Nick
